Giriş
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
Neye ihtiyacın var
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Bu adımda kullanılan alet:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Below the logic board, the small black microphone is resting within the case.
Bir başkası bu kılavuzu tamamladı.
