Ana içeriğe geç
VENSTAR Taco Speaker Replacement Replacement
Neye ihtiyacın var
  1. VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 1. VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 2. VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: adım 1, 3 resimden 3.
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    FixBot'a Sor
    Yorum Ekle
  2. VENSTAR Taco Speaker Replacement Replacement: adım 2, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 2, 2 resimden 2.
    • Repeat the previous step on the opposite side to remove the other outer casing.
    FixBot'a Sor
    Yorum Ekle
  3. VENSTAR Taco Speaker Replacement Replacement: adım 3, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    FixBot'a Sor
    Yorum Ekle
  4. VENSTAR Taco Speaker Replacement Replacement: adım 4, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 4, 2 resimden 2.
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    FixBot'a Sor
    Yorum Ekle
  5. VENSTAR Taco Speaker Replacement Replacement: adım 5, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 5, 2 resimden 2.
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    FixBot'a Sor
    Yorum Ekle
  6. VENSTAR Taco Speaker Replacement Replacement, Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the rubber covering from the buttons.
    FixBot'a Sor
    Yorum Ekle
  7. VENSTAR Taco Speaker Replacement Replacement: adım 7, 3 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 7, 3 resimden 2. VENSTAR Taco Speaker Replacement Replacement: adım 7, 3 resimden 3.
    • Remove the black fabric covering the logic board.
    FixBot'a Sor
    Yorum Ekle
  8. VENSTAR Taco Speaker Replacement Replacement: adım 8, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 8, 2 resimden 2.
    • Move the battery out of the way of the connector.
    FixBot'a Sor
    Yorum Ekle
  9. VENSTAR Taco Speaker Replacement Replacement: adım 9, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 9, 2 resimden 2.
    • Undo the connector of the flat white ribbon between the switches and the logic board.
    FixBot'a Sor
    Yorum Ekle
  10. VENSTAR Taco Speaker Replacement Replacement: adım 10, 1 resimden 1.
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. VENSTAR Taco Speaker Replacement Replacement: adım 11, 3 resimden 1. VENSTAR Taco Speaker Replacement Replacement: adım 11, 3 resimden 2. VENSTAR Taco Speaker Replacement Replacement: adım 11, 3 resimden 3.
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
    FixBot'a Sor
    Yorum Ekle
  12. VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: adım 12, 2 resimden 1. VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: adım 12, 2 resimden 2.
    • Using the Ph1 screwdriver, unscrew both of the 2.5mm screws on either side of the speakers.
    • The screws are glued in and may require the curved tweezers to pull all the way out.
    FixBot'a Sor
    Yorum Ekle
  13. VENSTAR Taco Speaker Replacement Replacement: adım 13, 1 resimden 1.
    • Using a metal spudger, carefully wedge out the speakers from the casing.
    • Repeat this step for the removal of the other speaker.
    • Speakers are glued into the casing beyond being screwed and require some care to remove.
    FixBot'a Sor
    Yorum Ekle
  14. VENSTAR Taco Speaker Replacement Replacement: adım 14, 1 resimden 1.
    • Using a portable soldering iron, melt the solder on the black speaker wires on the logic board.
    • Soldering uses hot metal and can burn you!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Solder your replacement speakers back to mother board, then to reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 645
