Ana içeriğe geç
VHS Shell Replacement
Neye ihtiyacın var
    1. VHS Shell Replacement, Plastic Shell: adım 1, 2 resimden 1. VHS Shell Replacement, Plastic Shell: adım 1, 2 resimden 2.
      • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. VHS Shell Replacement: adım 2, 1 resimden 1.
      • Once the screws are out, pull off the front of the VHS shell.
      • Take off any labels on the sides of tape before doing this step.
      • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
      FixBot'a Sor
      Yorum Ekle
    3. VHS Shell Replacement: adım 3, 2 resimden 1. VHS Shell Replacement: adım 3, 2 resimden 2.
      • Hold down on the white lever.
      • While holding down, carefully take out the reel on the right.
      • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
      FixBot'a Sor
      Yorum Ekle
    4. VHS Shell Replacement: adım 4, 2 resimden 1. VHS Shell Replacement: adım 4, 2 resimden 2.
      • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
      • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
      FixBot'a Sor
      Yorum Ekle
    5. VHS Shell Replacement: adım 5, 1 resimden 1.
      • Once the screws are out, pull off the front of the replacement shell.
      FixBot'a Sor
      Yorum Ekle
    6. VHS Shell Replacement: adım 6, 1 resimden 1.
      • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
      • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
      FixBot'a Sor
      Yorum Ekle
    7. VHS Shell Replacement: adım 7, 1 resimden 1.
      • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
      FixBot'a Sor
      Yorum Ekle
    8. VHS Shell Replacement: adım 8, 1 resimden 1.
      • Turn the reels to retract any excess tape hanging out of the top.
      • This isn't a necessary step, just one that I prefer to do.
      FixBot'a Sor
      Yorum Ekle
    9. VHS Shell Replacement: adım 9, 1 resimden 1.
      • Place the top of the replacement shell back on.
      FixBot'a Sor
      Yorum Ekle
    10. VHS Shell Replacement: adım 10, 1 resimden 1.
      • Screw the screws back in with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2Kılavuz Yorumları
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - Yanıt Paylaş
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 107
Her zaman: 3,939
