Ana içeriğe geç
VIZIO TV Screen Replacement
Neye ihtiyacın var
  1. VIZIO TV Screen Replacement, TV Screen: adım 1, 2 resimden 1. VIZIO TV Screen Replacement, TV Screen: adım 1, 2 resimden 2.
    • Please make sure to unplug the TV or completely remove the plug.
    • Carefully flip the TV over.
    • Start by unscrewing the bottom part of the TV.
  2. VIZIO TV Screen Replacement: adım 2, 3 resimden 1. VIZIO TV Screen Replacement: adım 2, 3 resimden 2. VIZIO TV Screen Replacement: adım 2, 3 resimden 3.
    • Unscrew the frame and slowly and carefully remove it. Set it somewhere.
    • Next, unscrew the nub and slowly and carefully remove it.
  3. VIZIO TV Screen Replacement: adım 3, 3 resimden 1. VIZIO TV Screen Replacement: adım 3, 3 resimden 2. VIZIO TV Screen Replacement: adım 3, 3 resimden 3.
    • Carefully unscrew all of the screws in the back of the TV.
  4. VIZIO TV Screen Replacement: adım 4, 3 resimden 1. VIZIO TV Screen Replacement: adım 4, 3 resimden 2. VIZIO TV Screen Replacement: adım 4, 3 resimden 3.
    • Slowly and carefully lift the back of the TV off and put it aside.
    • Next, we study the back of the TV, certain things can be removed and certain things can't. As we go through this guide, I will let you know what can be removed and what cannot. Please use the middle picture as a reference point.
    • The gray metal piece that is stationed underneath the yellowish device is the first thing that we will start to usncrew.
  5. VIZIO TV Screen Replacement: adım 5, 3 resimden 1. VIZIO TV Screen Replacement: adım 5, 3 resimden 2. VIZIO TV Screen Replacement: adım 5, 3 resimden 3.
    • Slowly lift up that gray panel and put it aside. Let's move on to the speakers.
    • The speakers are stationed on the side and you can just pull it up, it is magnetic and it can stick on the back of the TV very well. You do not need to unplug anything, you are just removing parts and putting them aside to move the screen.
  6. VIZIO TV Screen Replacement: adım 6, 3 resimden 1. VIZIO TV Screen Replacement: adım 6, 3 resimden 2. VIZIO TV Screen Replacement: adım 6, 3 resimden 3.
    • Remove the speakers.
    • Do not rip the speakers out. You can potentially pull out an important wire or damage it completely. Be very careful and gentle, set it aside.
    • Next, there is this little chip looking thing at the corner of the TV, take the small screwdriver and put it underneath it and lift it up. Be sure to again be gentle, making sure you don't scratch or chip it.
  7. VIZIO TV Screen Replacement: adım 7, 2 resimden 1. VIZIO TV Screen Replacement: adım 7, 2 resimden 2.
    • After you are done lifting it up, pull it towards you and lift it on top of the TV.
    • If your TV is different than mine, there might be more than one, make sure to find them and if they are connected around the frame, please remove them.
  8. VIZIO TV Screen Replacement, Buttons: adım 8, 3 resimden 1. VIZIO TV Screen Replacement, Buttons: adım 8, 3 resimden 2. VIZIO TV Screen Replacement, Buttons: adım 8, 3 resimden 3.
    • Next, we go to the buttons. My thumb is situated on a panel on top of the button, press on it.
    • With your other hand (keeping the thumb pressed on the panel), slowly and carefully lift the button part up.
    • Now, we are moving on to taking out this other medal piece (please see the last picture in this step).
  9. VIZIO TV Screen Replacement, More metal pieces: adım 9, 3 resimden 1. VIZIO TV Screen Replacement, More metal pieces: adım 9, 3 resimden 2. VIZIO TV Screen Replacement, More metal pieces: adım 9, 3 resimden 3.
    • There are two metal pieces holding onto the bottom of the TV. Really the bottom part of the TV is what's keeping you away from the glass part.
    • Unscrew both metal parts, slowly lifting them up and putting them aside, if you think labeling will help, please do so. These steps are easy enough to know and understand, so labeling is not really needed.
  10. VIZIO TV Screen Replacement, Sticky film: adım 10, 3 resimden 1. VIZIO TV Screen Replacement, Sticky film: adım 10, 3 resimden 2. VIZIO TV Screen Replacement, Sticky film: adım 10, 3 resimden 3.
    • There is this little sticker plastic thing that is located at the bottom. We are going to now use our pocket knife, the back part of it because we do not want to cut or rip that plastic section.
    • The tip of the knife should be used to help peel it and then the back of it should help lift it up.
    • It's okay, this is super sticky, so it will re-stick when you put it back together. Once done, go ahead and tuck it up (see last photo in this step) and move on to the next step.
  11. VIZIO TV Screen Replacement, Tiny Screws: adım 11, 3 resimden 1. VIZIO TV Screen Replacement, Tiny Screws: adım 11, 3 resimden 2. VIZIO TV Screen Replacement, Tiny Screws: adım 11, 3 resimden 3.
    • Here is where it gets a bit complicated. There is a lot of tiny little screws around the edge of the TV. Unscrew them going around and putting them aside.
    • Make sure to get every little screw, because when we flip the TV (super heavy!) we are going to remove the frame and if one screw is in there, it will be super difficult to remove.
    • Once you get all of the screws, go back and make sure you didn't leave one so we can do one quick flip and done. :)
  12. VIZIO TV Screen Replacement, Let's flip it... again!: adım 12, 3 resimden 1. VIZIO TV Screen Replacement, Let's flip it... again!: adım 12, 3 resimden 2. VIZIO TV Screen Replacement, Let's flip it... again!: adım 12, 3 resimden 3.
    • Now, again at the bottom, unclip the frame from the metal part. Make sure to do it carefully so that the plastic doesn't break.
    • Once done, flip the TV. It should look like the next two pictures.
  13. VIZIO TV Screen Replacement, Screen removal: adım 13, 3 resimden 1. VIZIO TV Screen Replacement, Screen removal: adım 13, 3 resimden 2. VIZIO TV Screen Replacement, Screen removal: adım 13, 3 resimden 3.
    • Next, we lift up the frame from in front of the TV (those tiny side screws did the work) and set it aside.
    • Once done, lift up the glass section (carefully, it is glass) and replace it with a brand new glass screen!
    • Make sure to match the right glass with the right TV, some of the glass can be a bit pricey (around $100 to $150) , but not as pricey as when someone else does it for you.
    • This is the end of this guide book!
    Where do u get the glass from
    Stacie Mcgruder-wallace - Yanıt
    that was helpful im hoping visio have a glass screan for a 32inch.. it was a great tv.. i love it but my mean ex broke the tv some how i really dont know but i hope can get one for it. thank you….
    Greg Millsap - Yanıt
    Where do you buy the screen. What website?
    Angel Rafael Rojas - Yanıt
    Where to buy replacement glass screen for vizio 40"
    Ugo Charles - Yanıt
    where did you get the screen for I need a 43" for that exact same tv. I have looked for 2 years, the only reason i want to fixmit so bad is because it was my grandfather's tv and he been dead since 2015
    Emmett Langley - Yanıt
    Dónde puedo conseguir estas pantallas para este tipo de televisor
    Luis alfredo Buitrago ortiz - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Ogania Gabriel
481 İtibar
1 Kılavuz yazıldı
10Kılavuz Yorumları
Where can you buy a screen ?
Allen Perkins - Yanıt
EBay, AliExpress, Alibaba, try the TV's manufacturer for parts Resources.
sean lowery -
I’m not sure how to make sense of this… Make sure to match the right glass with the right TV, some of the glass can be a bit pricey (around $100 to $150) , but not as pricey as when someone else does it for you.
Free Wheel Burning - Yanıt
I have a PX75 G1 Vizio tv LCD full array screen gone bad, can you suggest if one is available. Vizio does not carry or want to repair the TV that is just past couple of months after 2 years of warranty. Vizio will not even provide me with a part number.
Is there a way I can get it?.
Pankaj Patel - Yanıt
Confused, my Vizio D24f1 fell, 24" model - I have a black scratch now about 2 1/2 inches on "screen" - I have been told these can't be fixed as with older sets because of the anti-glare and other coatings that are on newer screens. Can this screen be fixed? Set is about 5 years old -
den2462002 - Yanıt
i have a vizio 55inch where did you buy the replacement. having a very hard time finding it.
Tatiana - Yanıt
I’m having problems finding a 75 inch screen for my Vizio v755-g4 any suggestions where I can find one
Esther - Yanıt
Can you post a link in the comments for the TV screen
Need screen for Vizio Model E65-E1
Angel Rivera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 76
Son 30 gün: 497
Her zaman: 34,863
