Ana içeriğe geç
VTech Baby's Learning Laptop Mode Switch Replacement
Neye ihtiyacın var
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
    FixBot'a Sor
    Yorum Ekle
  2. VTech Baby's Learning Laptop Mode Switch Replacement: adım 2, 1 resimden 1.
    • Remove the battery door.
    • Take out the batteries.
    FixBot'a Sor
    Yorum Ekle
  3. VTech Baby's Learning Laptop Mode Switch Replacement: adım 3, 1 resimden 1.
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
    FixBot'a Sor
    Yorum Ekle
  4. VTech Baby's Learning Laptop Mode Switch Replacement: adım 4, 2 resimden 1. VTech Baby's Learning Laptop Mode Switch Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
    FixBot'a Sor
    Yorum Ekle
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: adım 5, 2 resimden 1. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
    FixBot'a Sor
    Yorum Ekle
  6. VTech Baby's Learning Laptop Mode Switch Replacement: adım 6, 3 resimden 1. VTech Baby's Learning Laptop Mode Switch Replacement: adım 6, 3 resimden 2. VTech Baby's Learning Laptop Mode Switch Replacement: adım 6, 3 resimden 3.
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
    FixBot'a Sor
    Yorum Ekle
  7. VTech Baby's Learning Laptop Mode Switch Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
    FixBot'a Sor
    Yorum Ekle
  8. VTech Baby's Learning Laptop Mode Switch Replacement: adım 8, 1 resimden 1.
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Scott Parkinson
113 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 818
