Ana içeriğe geç
VTech Baby's Learning Laptop Mouse Replacement
Neye ihtiyacın var
    1. VTech Baby's Learning Laptop Mouse Replacement, Battery and Rear Panel: adım 1, 1 resimden 1.
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Mouse Replacement: adım 2, 1 resimden 1.
      • Remove the battery door.
      • Take out the batteries.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Mouse Replacement: adım 3, 1 resimden 1.
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      FixBot'a Sor
      Yorum Ekle
    4. VTech Baby's Learning Laptop Mouse Replacement: adım 4, 2 resimden 1. VTech Baby's Learning Laptop Mouse Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Baby's Learning Laptop Mouse Replacement, Mouse: adım 5, 2 resimden 1. VTech Baby's Learning Laptop Mouse Replacement, Mouse: adım 5, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Mouse Replacement: adım 6, 3 resimden 1. VTech Baby's Learning Laptop Mouse Replacement: adım 6, 3 resimden 2. VTech Baby's Learning Laptop Mouse Replacement: adım 6, 3 resimden 3.
      • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
      • Lay the board down gently and out of the way.
      • Take care not to damage any of the wires or the board itself.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Mouse Replacement: adım 7, 3 resimden 1. VTech Baby's Learning Laptop Mouse Replacement: adım 7, 3 resimden 2. VTech Baby's Learning Laptop Mouse Replacement: adım 7, 3 resimden 3.
      • Locate and remove the following screws:
      • Two 11.0mm Phillips #2.
      • Two 7.3mm Phillips #0.
      • Remove the top of the mouse which will separate from the under side once the screws are removed.
      • The metal connection near the yellow screws on the top left of the mouse assembly falls out very easily. Make sure to replace the metal connection with the prong pointing up. Otherwise, the mouse will not work correctly.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Baby's Learning Laptop Mouse Replacement: adım 8, 2 resimden 1. VTech Baby's Learning Laptop Mouse Replacement: adım 8, 2 resimden 2.
      • Lift the springs up from the screw pegs with a plastic opening tool.
      • Remove the final part of the mouse.
      • Before reassembly, see the note on the previous step.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin Schanze
266 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 1,699
