Ana içeriğe geç
VTech Baby's Learning Laptop Speaker Replacement
Neye ihtiyacın var
  1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Speaker Replacement: adım 4, 2 resimden 1. VTech Baby's Learning Laptop Speaker Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Speaker Replacement, Speaker: adım 5, 2 resimden 1. VTech Baby's Learning Laptop Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
  6. VTech Baby's Learning Laptop Speaker Replacement: adım 6, 2 resimden 1. VTech Baby's Learning Laptop Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the two 6 mm screws from the device.
    • Remove the speaker.
    • Be careful not to damage the wiring.
Sonuç
Jordan Smith
210 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
Where to buy the replacement speaker
hadbuckley - Yanıt
Where can you buy the replacement speaker please. I live in Sydney Australia
hadbuckley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,239
