Ana içeriğe geç
VTech Baby's Learning Laptop Volume Switch Replacement
Neye ihtiyacın var
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Battery and Rear Panel: adım 1, 1 resimden 1.
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 2, 1 resimden 1.
      • Remove the battery door.
      • Take out the batteries.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 3, 1 resimden 1.
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      FixBot'a Sor
      Yorum Ekle
    4. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 4, 2 resimden 1. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Volume Switch: adım 5, 1 resimden 1.
      • Flip your device so the bottom panel is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 6, 2 resimden 1. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 6, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 7, 2 resimden 1. VTech Baby's Learning Laptop Volume Switch  Replacement: adım 7, 2 resimden 2.
      • Remove the volume switch.
      • Be careful not damage the wiring.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jordan Smith
210 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 1,215
