Ana içeriğe geç
VTech Baby's Learning Laptop Buttons Replacement
Neye ihtiyacın var
    1. VTech Baby's Learning Laptop Buttons Replacement, Battery and Rear Panel: adım 1, 1 resimden 1.
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Buttons Replacement: adım 2, 1 resimden 1.
      • Remove the battery door.
      • Take out the batteries.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Buttons Replacement: adım 3, 1 resimden 1.
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      FixBot'a Sor
      Yorum Ekle
    4. VTech Baby's Learning Laptop Buttons Replacement: adım 4, 2 resimden 1. VTech Baby's Learning Laptop Buttons Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Baby's Learning Laptop Buttons Replacement, Buttons: adım 5, 1 resimden 1.
      • Using a Phillips #0 screwdriver remove the two 6.0mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Baby's Learning Laptop Buttons Replacement: adım 6, 2 resimden 1. VTech Baby's Learning Laptop Buttons Replacement: adım 6, 2 resimden 2.
      • Lift up on the board and set it aside.
      • Movement of the board will be limited. Be careful not to damage the connection to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Baby's Learning Laptop Buttons Replacement: adım 7, 1 resimden 1.
      • Remove each button and button contact.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 24
Her zaman: 1,316
