Ana içeriğe geç
VTech CS6719-2 Circuit Board Replacement
Neye ihtiyacın var
  1. VTech CS6719-2 Circuit Board Replacement, Battery: adım 1, 2 resimden 1. VTech CS6719-2 Circuit Board Replacement, Battery: adım 1, 2 resimden 2.
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Circuit Board Replacement: adım 2, 1 resimden 1.
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Circuit Board Replacement: adım 3, 1 resimden 1.
    • Unplug the battery input cable.
  4. VTech CS6719-2 Circuit Board Replacement: adım 4, 1 resimden 1.
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Circuit Board Replacement, Circuit Board: adım 5, 2 resimden 1. VTech CS6719-2 Circuit Board Replacement, Circuit Board: adım 5, 2 resimden 2.
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Circuit Board Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Circuit Board Replacement: adım 7, 2 resimden 1. VTech CS6719-2 Circuit Board Replacement: adım 7, 2 resimden 2.
    • Remove the two 9mm screws located inside the back cover at the top.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Benjamin Field
270 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G4
4 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
Jason Bellchamber - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 650
