Ana içeriğe geç
VTech InnoTab 2 Back Panel Replacement
Neye ihtiyacın var
  1. VTech InnoTab 2 Back Panel Replacement, Battery: adım 1, 3 resimden 1. VTech InnoTab 2 Back Panel Replacement, Battery: adım 1, 3 resimden 2. VTech InnoTab 2 Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
    FixBot'a Sor
    Yorum Ekle
  2. VTech InnoTab 2 Back Panel Replacement, Back Panel: adım 2, 3 resimden 1. VTech InnoTab 2 Back Panel Replacement, Back Panel: adım 2, 3 resimden 2. VTech InnoTab 2 Back Panel Replacement, Back Panel: adım 2, 3 resimden 3.
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
    FixBot'a Sor
    Yorum Ekle
  3. VTech InnoTab 2 Back Panel Replacement: adım 3, 3 resimden 1. VTech InnoTab 2 Back Panel Replacement: adım 3, 3 resimden 2. VTech InnoTab 2 Back Panel Replacement: adım 3, 3 resimden 3.
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. VTech InnoTab 2 Back Panel Replacement: adım 4, 2 resimden 1. VTech InnoTab 2 Back Panel Replacement: adım 4, 2 resimden 2.
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
    FixBot'a Sor
    Yorum Ekle
  5. VTech InnoTab 2 Back Panel Replacement: adım 5, 2 resimden 1. VTech InnoTab 2 Back Panel Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Roberto Valdes
302 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G85
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 741
