Ana içeriğe geç
VTech InnoTab 2 Backup Battery Replacement
Neye ihtiyacın var
  1. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: adım 1, 3 resimden 1. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: adım 1, 3 resimden 2. VTech InnoTab 2 Backup Battery Replacement, Backup Battery: adım 1, 3 resimden 3.
    • The CR2032 compartment is located on bottom left corner on the backside of the device.
    • Unscrew the single 4 mm Phillip screw and slide the compartment cover off.
    • The 4 mm Phillip screw will not completely screw out of the cover.
  2. VTech InnoTab 2 Backup Battery Replacement: adım 2, 3 resimden 1. VTech InnoTab 2 Backup Battery Replacement: adım 2, 3 resimden 2. VTech InnoTab 2 Backup Battery Replacement: adım 2, 3 resimden 3.
    • Gently remove the CR2032 battery with your fingers.
    • A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
Sonuç
Mark Lefcourt
201 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G85
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 456
