Ana içeriğe geç
VTech InnoTab 2 Camera Replacement
Neye ihtiyacın var
    1. VTech InnoTab 2 Camera Replacement, Battery: adım 1, 3 resimden 1. VTech InnoTab 2 Camera Replacement, Battery: adım 1, 3 resimden 2. VTech InnoTab 2 Camera Replacement, Battery: adım 1, 3 resimden 3.
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab 2 Camera Replacement, Back Panel: adım 2, 3 resimden 1. VTech InnoTab 2 Camera Replacement, Back Panel: adım 2, 3 resimden 2. VTech InnoTab 2 Camera Replacement, Back Panel: adım 2, 3 resimden 3.
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab 2 Camera Replacement: adım 3, 3 resimden 1. VTech InnoTab 2 Camera Replacement: adım 3, 3 resimden 2. VTech InnoTab 2 Camera Replacement: adım 3, 3 resimden 3.
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab 2 Camera Replacement: adım 4, 2 resimden 1. VTech InnoTab 2 Camera Replacement: adım 4, 2 resimden 2.
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab 2 Camera Replacement: adım 5, 2 resimden 1. VTech InnoTab 2 Camera Replacement: adım 5, 2 resimden 2.
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab 2 Camera Replacement, Camera: adım 6, 3 resimden 1. VTech InnoTab 2 Camera Replacement, Camera: adım 6, 3 resimden 2. VTech InnoTab 2 Camera Replacement, Camera: adım 6, 3 resimden 3.
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection to the camera is located on top side of the devices motherboard.
      • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
      • Attach the replacement camera and lower the latch until a click sound can be heard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Roberto Valdes
302 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G85
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 682
