Ana içeriğe geç
VTech InnoTab Max Battery Replacement
Neye ihtiyacın var
    1. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 1. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 2. VTech InnoTab Max Battery Replacement, Cover: adım 1, 3 resimden 3.
      • Remove all screw caps from the back panel using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 2, 3 resimden 3.
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab Max Battery Replacement: adım 3, 2 resimden 1. VTech InnoTab Max Battery Replacement: adım 3, 2 resimden 2.
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab Max Battery Replacement: adım 4, 2 resimden 1. VTech InnoTab Max Battery Replacement: adım 4, 2 resimden 2.
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab Max Battery Replacement, Battery: adım 5, 1 resimden 1.
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 1. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 2. VTech InnoTab Max Battery Replacement: adım 7, 3 resimden 3.
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab Max Battery Replacement: adım 8, 1 resimden 1.
      • The battery is now fully disconnected.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jacob Schioppo
594 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G5
3 Üyeler
10 adet Kılavuz yazıldı
10Kılavuz Yorumları
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - Yanıt Paylaş
Where can we purchase a replacement battery
Frank Godon - Yanıt Paylaş
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - Yanıt Paylaş
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 15,871
