Ana içeriğe geç
VTech InnoTab Max Camera Replacement
Neye ihtiyacın var
    1. VTech InnoTab Max Camera Replacement, Cover: adım 1, 3 resimden 1. VTech InnoTab Max Camera Replacement, Cover: adım 1, 3 resimden 2. VTech InnoTab Max Camera Replacement, Cover: adım 1, 3 resimden 3.
      • Remove all screw caps from the back panel using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab Max Camera Replacement: adım 2, 3 resimden 1. VTech InnoTab Max Camera Replacement: adım 2, 3 resimden 2. VTech InnoTab Max Camera Replacement: adım 2, 3 resimden 3.
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab Max Camera Replacement: adım 3, 2 resimden 1. VTech InnoTab Max Camera Replacement: adım 3, 2 resimden 2.
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab Max Camera Replacement: adım 4, 2 resimden 1. VTech InnoTab Max Camera Replacement: adım 4, 2 resimden 2.
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab Max Camera Replacement, Camera: adım 5, 1 resimden 1.
      • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab Max Camera Replacement: adım 6, 2 resimden 1. VTech InnoTab Max Camera Replacement: adım 6, 2 resimden 2.
      • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
      • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab Max Camera Replacement: adım 7, 1 resimden 1.
      • The camera is now removed completely removed from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Schioppo
594 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 858
