Ana içeriğe geç
VTech InnoTab Max Motherboard Replacement
Neye ihtiyacın var
  1. VTech InnoTab Max Motherboard Replacement, Cover: adım 1, 3 resimden 1. VTech InnoTab Max Motherboard Replacement, Cover: adım 1, 3 resimden 2. VTech InnoTab Max Motherboard Replacement, Cover: adım 1, 3 resimden 3.
    • Remove all screw caps from the back panel using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. VTech InnoTab Max Motherboard Replacement: adım 2, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 2, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 2, 3 resimden 3.
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. VTech InnoTab Max Motherboard Replacement: adım 3, 2 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 3, 2 resimden 2.
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. VTech InnoTab Max Motherboard Replacement: adım 4, 2 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 4, 2 resimden 2.
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
    FixBot'a Sor
    Yorum Ekle
  5. VTech InnoTab Max Motherboard Replacement, Battery: adım 5, 1 resimden 1.
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
    FixBot'a Sor
    Yorum Ekle
  6. VTech InnoTab Max Motherboard Replacement: adım 6, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 6, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
    FixBot'a Sor
    Yorum Ekle
  7. VTech InnoTab Max Motherboard Replacement: adım 7, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 7, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 7, 3 resimden 3.
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. VTech InnoTab Max Motherboard Replacement: adım 8, 1 resimden 1.
    • The battery is now fully disconnected.
    FixBot'a Sor
    Yorum Ekle
  9. VTech InnoTab Max Motherboard Replacement, Camera: adım 9, 1 resimden 1.
    • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
    FixBot'a Sor
    Yorum Ekle
  10. VTech InnoTab Max Motherboard Replacement: adım 10, 2 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 10, 2 resimden 2.
    • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
    • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
    FixBot'a Sor
    Yorum Ekle
  11. VTech InnoTab Max Motherboard Replacement: adım 11, 1 resimden 1.
    • The camera is now removed completely removed from the device.
    FixBot'a Sor
    Yorum Ekle
  12. VTech InnoTab Max Motherboard Replacement, Screen: adım 12, 2 resimden 1. VTech InnoTab Max Motherboard Replacement, Screen: adım 12, 2 resimden 2.
    • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
    • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
    FixBot'a Sor
    Yorum Ekle
  13. VTech InnoTab Max Motherboard Replacement: adım 13, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 13, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 13, 3 resimden 3.
    • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
    FixBot'a Sor
    Yorum Ekle
  14. VTech InnoTab Max Motherboard Replacement: adım 14, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 14, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 14, 3 resimden 3.
    • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
    • Be careful not to tear the film when pulling.
    FixBot'a Sor
    Yorum Ekle
  15. VTech InnoTab Max Motherboard Replacement: adım 15, 2 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 15, 2 resimden 2.
    • Once unclipped from the motherboard the screen should be entirely free from the device
    FixBot'a Sor
    Yorum Ekle
  16. VTech InnoTab Max Motherboard Replacement, Motherboard: adım 16, 1 resimden 1.
    • Remove the circled screws that are holding down the motherboard and components.
    • Every component that will need to be unscrewed will have wires running to it from the motherboard. These wires will not be disconnected.
    FixBot'a Sor
    Yorum Ekle
  17. VTech InnoTab Max Motherboard Replacement: adım 17, 3 resimden 1. VTech InnoTab Max Motherboard Replacement: adım 17, 3 resimden 2. VTech InnoTab Max Motherboard Replacement: adım 17, 3 resimden 3.
    • With all of the screws out, lift up the speaker, the two visible bronze plates, and the small green chip at the top.
    • Do not try to disconnect any of the wires running to these devices, as you will not be able to reconnect them.
    • All of these components can be located by following wires leaving the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. VTech InnoTab Max Motherboard Replacement: adım 18, 1 resimden 1.
    • With all of these components out of their place, lift up the motherboard to reveal one more bronze plate.
    • Remove the screws holding down this plate, and remove it with the rest of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. VTech InnoTab Max Motherboard Replacement: adım 19, 1 resimden 1.
    • All components should be free from the device, and you can now completely remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jacob Schioppo
594 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 2,514
