Giriş
This guide will show how to replace the motherboard in the VTech Innotab Max.
Neye ihtiyacın var
Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
Remove the circled screws that are holding down the motherboard and components.
3 farklı kişi bu kılavuzu tamamladı.
