Ana içeriğe geç
VTech InnoTab Max Screen Replacement
Neye ihtiyacın var
  1. VTech InnoTab Max Screen Replacement, Cover: adım 1, 3 resimden 1. VTech InnoTab Max Screen Replacement, Cover: adım 1, 3 resimden 2. VTech InnoTab Max Screen Replacement, Cover: adım 1, 3 resimden 3.
    • Remove all screw caps from the back panel using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. VTech InnoTab Max Screen Replacement: adım 2, 3 resimden 1. VTech InnoTab Max Screen Replacement: adım 2, 3 resimden 2. VTech InnoTab Max Screen Replacement: adım 2, 3 resimden 3.
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. VTech InnoTab Max Screen Replacement: adım 3, 2 resimden 1. VTech InnoTab Max Screen Replacement: adım 3, 2 resimden 2.
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. VTech InnoTab Max Screen Replacement: adım 4, 2 resimden 1. VTech InnoTab Max Screen Replacement: adım 4, 2 resimden 2.
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
    FixBot'a Sor
    Yorum Ekle
  5. VTech InnoTab Max Screen Replacement, Battery: adım 5, 1 resimden 1.
    • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
    FixBot'a Sor
    Yorum Ekle
  6. VTech InnoTab Max Screen Replacement: adım 6, 3 resimden 1. VTech InnoTab Max Screen Replacement: adım 6, 3 resimden 2. VTech InnoTab Max Screen Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
    • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
    • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
    FixBot'a Sor
    Yorum Ekle
  7. VTech InnoTab Max Screen Replacement: adım 7, 3 resimden 1. VTech InnoTab Max Screen Replacement: adım 7, 3 resimden 2. VTech InnoTab Max Screen Replacement: adım 7, 3 resimden 3.
    • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. VTech InnoTab Max Screen Replacement: adım 8, 1 resimden 1.
    • The battery is now fully disconnected.
    FixBot'a Sor
    Yorum Ekle
  9. VTech InnoTab Max Screen Replacement, Screen: adım 9, 2 resimden 1. VTech InnoTab Max Screen Replacement, Screen: adım 9, 2 resimden 2.
    • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
    • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
    FixBot'a Sor
    Yorum Ekle
  10. VTech InnoTab Max Screen Replacement: adım 10, 3 resimden 1. VTech InnoTab Max Screen Replacement: adım 10, 3 resimden 2. VTech InnoTab Max Screen Replacement: adım 10, 3 resimden 3.
    • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
    FixBot'a Sor
    Yorum Ekle
  11. VTech InnoTab Max Screen Replacement: adım 11, 3 resimden 1. VTech InnoTab Max Screen Replacement: adım 11, 3 resimden 2. VTech InnoTab Max Screen Replacement: adım 11, 3 resimden 3.
    • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
    • Be careful not to tear the film when pulling.
    FixBot'a Sor
    Yorum Ekle
  12. VTech InnoTab Max Screen Replacement: adım 12, 2 resimden 1. VTech InnoTab Max Screen Replacement: adım 12, 2 resimden 2.
    • Once unclipped from the motherboard the screen should be entirely free from the device
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jacob Schioppo
594 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G5
3 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where can I buy a screen
Damien Hennigan - Yanıt Paylaş
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - Yanıt Paylaş
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - Yanıt Paylaş
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 39
Her zaman: 5,809
