Ana içeriğe geç
VTech Kidizoom Action Cam Buttons Replacement
Neye ihtiyacın var
  1. VTech Kidizoom Action Cam Buttons Replacement, Display Assembly: adım 1, 1 resimden 1.
    • Make sure that the master power switch is set to the (O) position.
    FixBot'a Sor
    Yorum Ekle
  2. VTech Kidizoom Action Cam Buttons Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
    • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
    FixBot'a Sor
    Yorum Ekle
  3. VTech Kidizoom Action Cam Buttons Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
    • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
    • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
    FixBot'a Sor
    Yorum Ekle
  4. VTech Kidizoom Action Cam Buttons Replacement: adım 4, 1 resimden 1.
    • Pry off the transparent plating and paper design using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. VTech Kidizoom Action Cam Buttons Replacement: adım 5, 1 resimden 1.
    • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. VTech Kidizoom Action Cam Buttons Replacement: adım 6, 1 resimden 1.
    • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
    FixBot'a Sor
    Yorum Ekle
  7. VTech Kidizoom Action Cam Buttons Replacement: adım 7, 3 resimden 1. VTech Kidizoom Action Cam Buttons Replacement: adım 7, 3 resimden 2. VTech Kidizoom Action Cam Buttons Replacement: adım 7, 3 resimden 3.
    • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
    • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. VTech Kidizoom Action Cam Buttons Replacement, Buttons: adım 8, 2 resimden 1. VTech Kidizoom Action Cam Buttons Replacement, Buttons: adım 8, 2 resimden 2.
    • Push out the buttons that you wish to take out, and replace them with the new buttons.
    • Cleaning the buttons may fix the issue of sticky buttons, and a replacement may not be necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ross Anderson
630 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Sullivan Spring 2016 USF Tampa, Team 3-5, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 3,053
