Ana içeriğe geç
VTech Kidizoom Camera Connect Front Case Replacement
Neye ihtiyacın var
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: adım 1, 2 resimden 1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: adım 1, 2 resimden 2.
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: adım 2, 2 resimden 1. VTech Kidizoom Camera Connect Front Case Replacement: adım 2, 2 resimden 2.
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: adım 3, 3 resimden 1. VTech Kidizoom Camera Connect Front Case Replacement: adım 3, 3 resimden 2. VTech Kidizoom Camera Connect Front Case Replacement: adım 3, 3 resimden 3.
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: adım 4, 1 resimden 1.
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Foster
288 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 4,098
