Ana içeriğe geç
VTech Kidizoom Camera Connect Shutter Button Replacement
Neye ihtiyacın var
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: adım 1, 2 resimden 1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: adım 1, 2 resimden 2.
      • Remove batteries and SD card before beginning disassembly!
      • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 2, 2 resimden 1. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 2, 2 resimden 2.
      • Remove all four (11mm) screws with the Philips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 3, 3 resimden 1. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 3, 3 resimden 2. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 3, 3 resimden 3.
      • Remove the two battery cartridges located on the underside of the camera.
      • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 4, 1 resimden 1.
      • Beware of the two black viewfinder lens falling out as you pry open the device!
      • The device should now be open and ready for further repair and/or replacement parts.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: adım 5, 1 resimden 1.
      • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 6, 1 resimden 1.
      • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 7, 2 resimden 1. VTech Kidizoom Camera Connect Shutter Button Replacement: adım 7, 2 resimden 2.
      • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Justin Sanchez
544 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 1,609
