Ana içeriğe geç
VTech Kidizoom Smartwatch DX2 Battery Replacement
Neye ihtiyacın var
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: adım 1, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: adım 1, 2 resimden 2.
      • Begin by flipping the watch over with its back facing upwards.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 2, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 2, 2 resimden 2.
      • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 3, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 3, 2 resimden 2.
      • Gently lift the backplate up to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 4, 3 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 4, 3 resimden 2. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 4, 3 resimden 3.
      • After removing the backplate, lift the master switch up from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: adım 5, 1 resimden 1.
      • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 6, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 6, 2 resimden 2.
      • Carefully remove the speaker from the case without disconnecting it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 7, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using the tweezers, carefully lift the bar holding the connection to the screen.
      • Remove the motherboard from the device.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: adım 8, 1 resimden 1.
      • Carefully pry the battery off of the circuit board using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: adım 9, 1 resimden 1.
      • De-solder the wires connecting the battery to the circuit board.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Richard
515 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G5
4 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Yanıt Paylaş
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Can I cut the wires connected?
TECH DUDE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 84
Her zaman: 11,739
