Ana içeriğe geç
VTech Kidizoom Smartwatch DX2 Camera Replacement
Neye ihtiyacın var
  1. VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: adım 1, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: adım 1, 2 resimden 2.
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 2, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 2, 2 resimden 2.
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 3, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 3, 2 resimden 2.
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 4, 3 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 4, 3 resimden 2. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 4, 3 resimden 3.
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Camera Replacement, Motherboard: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 6, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 6, 2 resimden 2.
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 7, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement: adım 7, 2 resimden 2.
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: adım 8, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: adım 8, 2 resimden 2.
    • Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
    • Carefully lift the clips and slide the cameras out.
Sonuç
Nathaniel Cady
181 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G5
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
to much and do not under stand it
Aaron Arora - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 764
