Ana içeriğe geç
VTech Kidizoom Smartwatch DX2 Master Switch Replacement
Neye ihtiyacın var
    1. VTech Kidizoom Smartwatch DX2 Master Switch Replacement, Master Switch: adım 1, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Master Switch Replacement, Master Switch: adım 1, 2 resimden 2.
      • Begin by flipping the watch over with its back facing upwards.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 2, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 2, 2 resimden 2.
      • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 3, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 3, 2 resimden 2.
      • Gently lift the backplate up to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 4, 3 resimden 1. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 4, 3 resimden 2. VTech Kidizoom Smartwatch DX2 Master Switch Replacement: adım 4, 3 resimden 3.
      • After removing the backplate, lift the master switch up from the circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sydney
368 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G5
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 2,399
