Ana içeriğe geç
VTech Kidizoom Smartwatch DX2 Motherboard Replacement
Neye ihtiyacın var
    1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: adım 1, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: adım 1, 2 resimden 2.
      • Begin by flipping the watch over with its back facing upwards.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 2, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 2, 2 resimden 2.
      • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 3, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 3, 2 resimden 2.
      • Gently lift the backplate up to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 4, 3 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 4, 3 resimden 2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 4, 3 resimden 3.
      • After removing the backplate, lift the master switch up from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
      • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 6, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 6, 2 resimden 2.
      • Carefully remove the speaker from the case without disconnecting it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 7, 2 resimden 1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using the tweezers, carefully lift the bar holding the connection to the screen.
      • Remove the motherboard from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jessica Richard
515 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G5
4 Üyeler
7 adet Kılavuz yazıldı
3Kılavuz Yorumları
This shows how to take the motherboard out, but how to I get a replacement motherboard? I don’t see anywhere that I can purchase one…
ltiede12 - Yanıt Paylaş
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
Asher Kobin - Yanıt Paylaş
Which screen is the motherboard connected to bcause I have to replace it cause it is broken
TECH DUDE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 4,448
