Ana içeriğe geç
VTech Learning Tunes Karaoke Mode Selector Replacement
Neye ihtiyacın var
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
    FixBot'a Sor
    Yorum Ekle
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 2, 2 resimden 1. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 2, 2 resimden 2.
    • Remove the battery door and take out the batteries.
    FixBot'a Sor
    Yorum Ekle
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 3, 1 resimden 1.
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 4, 2 resimden 1. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 5, 1 resimden 1.
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
    FixBot'a Sor
    Yorum Ekle
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 6, 2 resimden 1. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 6, 2 resimden 2.
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
    FixBot'a Sor
    Yorum Ekle
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 7, 2 resimden 1. VTech Learning Tunes Karaoke Mode Selector Replacement: adım 7, 2 resimden 2.
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Adam Chaberek
137 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 625
