Ana içeriğe geç
VTech Learning Tunes Karaoke Power Button Replacement
Neye ihtiyacın var
    1. VTech Learning Tunes Karaoke Power Button Replacement, Power Button: adım 1, 1 resimden 1.
      • To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
      • A coin can also be used to loosen the screw
      FixBot'a Sor
      Yorum Ekle
    2. VTech Learning Tunes Karaoke Power Button Replacement: adım 2, 2 resimden 1. VTech Learning Tunes Karaoke Power Button Replacement: adım 2, 2 resimden 2.
      • Remove the battery door and take out the batteries.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Learning Tunes Karaoke Power Button Replacement: adım 3, 1 resimden 1.
      • Remove the six 9.5 mm Phillips #2 screws.
      • Remove the six 6.0 mm Phillips #2 screws.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Learning Tunes Karaoke Power Button Replacement: adım 4, 2 resimden 1. VTech Learning Tunes Karaoke Power Button Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the rear panel.
      • Be careful to not pull on the wire connections.
      • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    5. VTech Learning Tunes Karaoke Power Button Replacement: adım 5, 1 resimden 1.
      • Remove four 7.9 mm screws from the mode selector and voice selector trays.
      FixBot'a Sor
      Yorum Ekle
    6. VTech Learning Tunes Karaoke Power Button Replacement: adım 6, 1 resimden 1.
      • Remove the two 5.6 mm screws from the power button board.
      FixBot'a Sor
      Yorum Ekle
    7. VTech Learning Tunes Karaoke Power Button Replacement: adım 7, 1 resimden 1.
      • Carefully move the power button board out of the way.
      • From here you can replace the button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Gamuchirai Chifamba
249 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 719
