Ana içeriğe geç
VTech MobiGo Touch Learning System Case Replacement
Neye ihtiyacın var
  1. VTech MobiGo Touch Learning System Case Replacement, Case: adım 1, 1 resimden 1.
    • Remove the battery covers and the four batteries.
    FixBot'a Sor
    Yorum Ekle
  2. VTech MobiGo Touch Learning System Case Replacement: adım 2, 2 resimden 1. VTech MobiGo Touch Learning System Case Replacement: adım 2, 2 resimden 2.
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
    FixBot'a Sor
    Yorum Ekle
  3. VTech MobiGo Touch Learning System Case Replacement: adım 3, 2 resimden 1. VTech MobiGo Touch Learning System Case Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, separate the two pieces of the case carefully.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Daniel Kresge
385 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G3
3 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 58
Her zaman: 1,399
