Ana içeriğe geç
VTech MobiGo Touch Learning System Screen Replacement
Neye ihtiyacın var
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: adım 1, 1 resimden 1.
    • Remove the battery covers and the four batteries.
    FixBot'a Sor
    Yorum Ekle
  2. VTech MobiGo Touch Learning System Screen Replacement: adım 2, 2 resimden 1. VTech MobiGo Touch Learning System Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
    FixBot'a Sor
    Yorum Ekle
  3. VTech MobiGo Touch Learning System Screen Replacement: adım 3, 2 resimden 1. VTech MobiGo Touch Learning System Screen Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, separate the two pieces of the case carefully.
    FixBot'a Sor
    Yorum Ekle
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: adım 4, 1 resimden 1.
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
    FixBot'a Sor
    Yorum Ekle
  5. VTech MobiGo Touch Learning System Screen Replacement: adım 5, 1 resimden 1.
    • Remove the three "L" shaped brackets and the spring.
    FixBot'a Sor
    Yorum Ekle
  6. VTech MobiGo Touch Learning System Screen Replacement: adım 6, 1 resimden 1.
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
    FixBot'a Sor
    Yorum Ekle
  7. VTech MobiGo Touch Learning System Screen Replacement: adım 7, 1 resimden 1.
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
    FixBot'a Sor
    Yorum Ekle
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: adım 8, 1 resimden 1.
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
    FixBot'a Sor
    Yorum Ekle
  9. VTech MobiGo Touch Learning System Screen Replacement: adım 9, 1 resimden 1.
    • Remove the black tape
    FixBot'a Sor
    Yorum Ekle
  10. VTech MobiGo Touch Learning System Screen Replacement: adım 10, 1 resimden 1.
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
    FixBot'a Sor
    Yorum Ekle
  11. VTech MobiGo Touch Learning System Screen Replacement: adım 11, 1 resimden 1.
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
    FixBot'a Sor
    Yorum Ekle
  12. VTech MobiGo Touch Learning System Screen Replacement: adım 12, 1 resimden 1.
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Kresge
385 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G3
3 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
mine i droped a rock on so i don’t get it
Jesse Eagan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,244
