Ana içeriğe geç
VTech Safe And Sound DM221 Speaker Replacement
Neye ihtiyacın var
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: adım 2, 1 resimden 1.
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: adım 3, 1 resimden 1.
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: adım 4, 1 resimden 1.
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: adım 7, 1 resimden 1.
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: adım 8, 1 resimden 1.
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: adım 9, 1 resimden 1.
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Sonuç
Krystal
600 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Leahy Fall 2015 USF Tampa, Team 1-5, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 383
