Giriş
Use this guide if buttons are damaged or if button inputs are unresponsive. Button replacement may require replacement of motherboard. While working on this device, make sure that the device is powered off and not plugged into the wall, as this may cause electrostatic shock.
Neye ihtiyacın var
Expose the battery compartment by removing the lower back cover of the device.
Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
Remove the two 11.2 mm Philips #00 screws located on either side of the battery slots.
Bir başkası bu kılavuzu tamamladı.
