Ana içeriğe geç
VTech VM3254 Battery Replacement
Neye ihtiyacın var
  1. VTech VM3254 Battery Replacement, Battery: adım 1, 2 resimden 1. VTech VM3254 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
    FixBot'a Sor
    Yorum Ekle
  2. VTech VM3254 Battery Replacement: adım 2, 3 resimden 1. VTech VM3254 Battery Replacement: adım 2, 3 resimden 2. VTech VM3254 Battery Replacement: adım 2, 3 resimden 3.
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
    FixBot'a Sor
    Yorum Ekle
  3. VTech VM3254 Battery Replacement: adım 3, 2 resimden 1. VTech VM3254 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
    FixBot'a Sor
    Yorum Ekle
  4. VTech VM3254 Battery Replacement: adım 4, 3 resimden 1. VTech VM3254 Battery Replacement: adım 4, 3 resimden 2. VTech VM3254 Battery Replacement: adım 4, 3 resimden 3.
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jackson Meacham
109 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
What is the battery that needs to be replaced called?
Aden Brooks - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 66
Her zaman: 2,954
