Giriş
If the VTech VM3245 will not switch on, the battery may need to be replaced. The information below specifically states how to remove the battery and replace it with a new one. The only tools needed include a Phillips #00 screwdriver, Jimmy, and one opening pick. You will not have any difficult steps, but remove the front cover of the device attentively.
Neye ihtiyacın var
Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
