Ana içeriğe geç
VTech Write and Learn Creative Center Magnetic Pen Replacement
Neye ihtiyacın var
  1. VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: adım 1, 3 resimden 1. VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: adım 1, 3 resimden 2. VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Pen Replacement, Magnetic Pen: adım 2, 1 resimden 1.
    • If there is any hot glue, remove it from the base of the wires.
    • During reassembly, reapply the hot glue to the connections to reinforce it's strength.
  3. VTech Write and Learn Creative Center Magnetic Pen Replacement: adım 3, 1 resimden 1.
    • In order to remove the magnetic pen, you must desolder the two wires connecting it to the circuit board.
    • When you desolder, apply the tip of the soldering iron to the soldered joint for approximately 5 - 10 seconds.
    • The soldered joint will turn to a liquid consistency. At this moment, remove the wire and soldering iron.
    • Repeat each of the following steps for the second soldered joint.
    • Soldering irons are dangerously hot. The soldering iron should only come in contact with joints being desoldered or soldered.
    • Make sure to allow time for your soldering iron to heat up before using it.
    • Make sure the tip of the soldering iron is cleaned so the tin on the tip is exposed. This will allow the soldering iron to work efficiently.
  4. VTech Write and Learn Creative Center Magnetic Pen Replacement: adım 4, 3 resimden 1. VTech Write and Learn Creative Center Magnetic Pen Replacement: adım 4, 3 resimden 2. VTech Write and Learn Creative Center Magnetic Pen Replacement: adım 4, 3 resimden 3.
    • Undo the knot, then feed the cord from the inside of the case to the outside using the hole the company originally designed for the cord.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Victoria Hathaway
331 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G2
3 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
Great write up. Where did you buy the replacement pen?
Jeff Donkersley - Yanıt
Where do you purchase the replacement pen please?
Ben Rieff - Yanıt
Where can I buy a replacement pen?
Simone Wisdom - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 2,778
