Ana içeriğe geç
VTech Write and Learn Creative Center Slider Replacement
Neye ihtiyacın var
    1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: adım 1, 3 resimden 1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: adım 1, 3 resimden 2. VTech Write and Learn Creative Center Slider Replacement, Back Panel: adım 1, 3 resimden 3.
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      FixBot'a Sor
      Yorum Ekle
    1. VTech Write and Learn Creative Center Slider Replacement, Slider: adım 2, 1 resimden 1.
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Philip Zietkowski
345 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G2
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 766
