Ana içeriğe geç
VTechCS6719-16 Button Replacement
Neye ihtiyacın var
  1. VTechCS6719-16 Button Replacement, Buttons: adım 1, 1 resimden 1.
    • Remove the sliding back cover from case.
    FixBot'a Sor
    Yorum Ekle
  2. VTechCS6719-16 Button Replacement: adım 2, 1 resimden 1.
    • lift the battery and unplug the two pin cable from phone base.
    FixBot'a Sor
    Yorum Ekle
  3. VTechCS6719-16 Button Replacement: adım 3, 1 resimden 1.
    • Remove the two 10mm screws at the base of the phone .
    FixBot'a Sor
    Yorum Ekle
  4. VTechCS6719-16 Button Replacement: adım 4, 1 resimden 1.
    • Use the spudger along the edge using a firm but gentle lifting motion.
    • When doing this feel for the hooks that latch the phones front and back cases.
    FixBot'a Sor
    Yorum Ekle
  5. VTechCS6719-16 Button Replacement: adım 5, 1 resimden 1.
    • Unscrew a second set of 10mm screws to obtain access to the other side.
    FixBot'a Sor
    Yorum Ekle
  6. VTechCS6719-16 Button Replacement: adım 6, 1 resimden 1.
    • The front of the phone can now be placed to the side
    • You will notice the button covers, these display the numerical values and positions of each button
    • These can be placed aside as they will get in the way later.
    FixBot'a Sor
    Yorum Ekle
  7. VTechCS6719-16 Button Replacement: adım 7, 1 resimden 1.
    • Now the silicon pads for the phone buttons are exposed.
    • These can easily be removed by pulling away the pads from the circuit board.
    • To replace simply align the new pad onto the button positions.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Charles montes
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 418
