Ana içeriğe geç
VTechCS6719-16 Screen Replacement
Neye ihtiyacın var
  1. VTechCS6719-16 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Slide the back cover off the cause.
    FixBot'a Sor
  2. VTechCS6719-16 Screen Replacement: adım 2, 1 resimden 1.
    • Lift the battery.
    • Unplug the two pin cable from the connector.
    FixBot'a Sor
  3. VTechCS6719-16 Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the two 10mm screws in phone base.
    FixBot'a Sor
  4. VTechCS6719-16 Screen Replacement: adım 4, 1 resimden 1.
    • Using the metal spudger gently, but firmly edge along the device .
    • When you feel a hook or latch use a firm but gentle lifting motion upward to unlatch the front and back case.
    FixBot'a Sor
  5. VTechCS6719-16 Screen Replacement: adım 5, 1 resimden 1.
    • Unscrew a second set of 10mm screws to access to the other side.
    FixBot'a Sor
  6. VTechCS6719-16 Screen Replacement: adım 6, 1 resimden 1.
    • The front case is now free and able to be manipulated.
    • Set aside the circuit board and back case as they will get in the way.
    FixBot'a Sor
  7. VTechCS6719-16 Screen Replacement: adım 7, 1 resimden 1.
    • Using a single finger apply a light force on the screen cover to release from the case.
    • Now the old screen can be replaced with a new desired one, simply properly align and it will clip into place.
    FixBot'a Sor
Sonuç
Charles montes
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 40
Her zaman: 382
