Ana içeriğe geç
Vacuum Cleaner Brush Roll Replacement
Neye ihtiyacın var
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: adım 1, 1 resimden 1.
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: adım 2, 2 resimden 1. Vacuum Cleaner Brush Roll Replacement: adım 2, 2 resimden 2.
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: adım 3, 1 resimden 1.
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: adım 4, 1 resimden 1.
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: adım 5, 2 resimden 1. Vacuum Cleaner Brush Roll Replacement: adım 5, 2 resimden 2.
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: adım 6, 2 resimden 1. Vacuum Cleaner Brush Roll Replacement: adım 6, 2 resimden 2.
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: adım 7, 1 resimden 1.
    • Return the clean brush roll and re-situate the belt to secure it in place.
Sonuç
To reassemble your device, follow the disassembly instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 95
Her zaman: 3,885
