Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Be sure to unplug the device from the wall outlet before disassembling.
Remove the bottom head of the vacuum cleaner by pressing the push button.
Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
Separate the top portion of the head from the bottom.
Make sure not to pull off or damage the connected wires.
Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
Return the clean brush roll and re-situate the belt to secure it in place.
