Ana içeriğe geç
Giriş
This guide will instruct you, step by step, in how to remove and replace the disk drive in your Vaio VGRFS640.
  1. Turn off the laptop and disconnect any charging cables.
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Remove the backplate of the laptop by pulling it away from the laptop.
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Unscrew the screws holding in the CD/ DVD drive. Unscrew the screws holding in the CD/ DVD drive.
    • Unscrew the screws holding in the CD/ DVD drive.
  11. Remove the CD/ DVD drive by gently lifting it up and out of the laptop. Remove the CD/ DVD drive by gently lifting it up and out of the laptop.
    • Remove the CD/ DVD drive by gently lifting it up and out of the laptop.
  12. Get the new CD/ DVD drive. Make sure that the new CD/ DVD drive is compatable with the Vaio VGRFS640
    • Get the new CD/ DVD drive.
    • Make sure that the new CD/ DVD drive is compatable with the Vaio VGRFS640
    • Sony no-longer has a list of compatable drivers, however the original driver can be found here under optical drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoffrey
252 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S2G6
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 161
