Giriş
If the battery in your Van Heusen PC21J watch has stopped working, follow this guide to replace it.
Neye ihtiyacın var
Lay the watch on its side just like this
Grab tweezers and poke the hole which connects the stainless steel to the band, to disconnect the steel holding it together.
The pin should come out. This pin is important so place it somewhere to the side for now. After that, your watch should look like this when laid out flat, allowing you more room to work with to replace your battery.
Sonuç
