Ana içeriğe geç
VanMoof No 3 Light Battery Replacement
Neye ihtiyacın var
  1. VanMoof No 3 Light Battery Replacement, Battery: adım 1, 3 resimden 1. VanMoof No 3 Light Battery Replacement, Battery: adım 1, 3 resimden 2. VanMoof No 3 Light Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: adım 2, 1 resimden 1.
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: adım 3, 2 resimden 1. VanMoof No 3 Light Battery Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: adım 4, 2 resimden 1. VanMoof No 3 Light Battery Replacement, Unsolder the battery: adım 4, 2 resimden 2.
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: adım 5, 3 resimden 1. VanMoof No 3 Light Battery Replacement, Solder the new battery: adım 5, 3 resimden 2. VanMoof No 3 Light Battery Replacement, Solder the new battery: adım 5, 3 resimden 3.
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: adım 6, 1 resimden 1.
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: adım 7, 3 resimden 1. VanMoof No 3 Light Battery Replacement, Reassemble: adım 7, 3 resimden 2. VanMoof No 3 Light Battery Replacement, Reassemble: adım 7, 3 resimden 3.
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: adım 8, 2 resimden 1. VanMoof No 3 Light Battery Replacement, Reassemble 2: adım 8, 2 resimden 2.
    • Test the light turns on
    • Screw the back plate to the lense.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Martin Hampton
1.308 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 95
Her zaman: 9,005
