Ana içeriğe geç
Vankyo Projector Leisure 3 Polarized Lens Glass Replacement
Neye ihtiyacın var
  1. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement, Polarized Lens Glass: adım 1, 1 resimden 1.
    • Disconnect the projector from any power source and allow it to cool down before starting the repair.
  2. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 2, 3 resimden 1. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 2, 3 resimden 2. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 2, 3 resimden 3.
    • Place the projector upside down.
    • Use a Phillips #00 screwdriver to remove the five 1.5mm screws from the base of the projector.
    • Remove the base of the project.
    • There is a cable attached to the motherboard and the bottom case of the projector so don't yank or pull it off.
  3. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 3, 3 resimden 1. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 3, 3 resimden 2. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove four 1.0 mm screws from the black cover.
    • Slowly lift the black triangular shaped cover and gently place it aside.
  4. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 4, 3 resimden 1. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 4, 3 resimden 2. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 4, 3 resimden 3.
    • Carefully remove the old polarized glass lens by lifting it up and out of the slot.
    • Take extra care while working with the polarized lens glass to avoid breaking it and damaging the projector or getting cut.
  5. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: adım 5, 1 resimden 1.
    • Gently replace the new polarized glass.
Sonuç
Congratulations! You have successfully completed the replacement of the polarized lens glass in your Vankyo Projector Leisure 3. By following this guide, you have taken a crucial step towards restoring optimal image quality and ensuring a satisfying viewing experience.
Remember, the polarized lens glass plays a vital role in filtering light and enhancing the projected images. By addressing issues such as blurry or distorted images, you have effectively resolved common problems associated with a damaged or worn-out lens.
We hope this guide has empowered you to take charge of the repair process and provided valuable insights into the inner workings of your projector. Remember to handle the polarized lens glass with care.
Now that you have successfully completed this repair, you can enjoy your Vankyo Projector Leisure 3 with renewed clarity and vibrancy in its projections. Should you encounter any future issues or require additional repairs, don't hesitate to consult further resources or reach out for assistance.
Thank you for using this guide, and we wish you many enjoyable movie nights and presentations with your Vankyo Projector Leisure 3!
2 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Thank you for the guide! Where do we get a replacement polarized glass lens from?
Jenna Lee - Yanıt
Hello! I found a replacement on eBay, I haven't received it yet, but I saw this comment before hunting for one online! I would've waited until I received it to be sure it's good, but I know I'll most certainly forget, plus the seller has pretty solid reviews.
https://www.ebay.com/itm/115448154872
V Villa -
I found a replacement polarizer on AliExpress for my Vankyo v630w, specifically for my model. Perhaps they also have the Leisure model as well.
Amazon has one for 54.00 USD but the AliExpress listing was only 16.00 USD plus shipping and a bit of wait time
Wayne Thomason - Yanıt
Can you send me details?
Doodles -
I am attempting this. I bought the recommended part from eBay. The eBay vendor asks for my existing Vankyo...
1, the LCD screen it is Light-transmissive or not? please try it by toward the lcd screen to the light,
2, the numbers on the LCD screen,
the information are needed to confirm the matched item for you,
Help!
Reply
Doodles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 36
Son 30 gün: 167
Her zaman: 2,855
