Ana içeriğe geç
Velocity Micro Cruz T301 Motherboard Replacement
Neye ihtiyacın var
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: adım 1, 1 resimden 1.
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: adım 2, 1 resimden 1.
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: adım 3, 1 resimden 1.
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: adım 4, 2 resimden 1. Velocity Micro Cruz T301 Motherboard  Replacement: adım 4, 2 resimden 2.
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: adım 5, 1 resimden 1.
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: adım 6, 1 resimden 1.
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: adım 7, 1 resimden 1.
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: adım 8, 1 resimden 1.
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: adım 9, 1 resimden 1.
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: adım 10, 1 resimden 1.
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: adım 11, 1 resimden 1.
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: adım 12, 2 resimden 1. Velocity Micro Cruz T301 Motherboard  Replacement: adım 12, 2 resimden 2.
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: adım 13, 1 resimden 1.
    • use openning tools to remove the motherboard.
Sonuç
Ahmed
227 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 164
