Ana içeriğe geç
Velocity NoteMagix M10 A82 Cooling Fan Replacement
Neye ihtiyacın var
  1. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 2, 2 resimden 1. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Keyboard: adım 3, 1 resimden 1.
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
  6. Velocity NoteMagix M10 A82 Cooling Fan Replacement, Cooling Fan: adım 6, 1 resimden 1.
    • Remove the eight 5.65mm Phillips #1 screws.
  7. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 7, 2 resimden 1. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Place the computer open and with the screen facing up on the table.
    • Remove the three 3.65mm Phillips #1 screws in the right hand corner. Also remove the mirrored set of screws on the left side.
  8. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
  9. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
  10. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 10, 2 resimden 1. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 10, 2 resimden 2.
    • Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
  11. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 11, 1 resimden 1.
    • Remove the two 4.80mm Phillips #00 screws holding down the fan.
  12. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 12, 2 resimden 1. Velocity NoteMagix M10 A82 Cooling Fan Replacement: adım 12, 2 resimden 2.
    • Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
Sonuç
Jaymes Lee
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G9
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 500
