Ana içeriğe geç
Velocity NoteMagix M10 A82 Hard Drive Replacement
Neye ihtiyacın var
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: adım 2, 2 resimden 1. Velocity NoteMagix M10 A82 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: adım 5, 2 resimden 1. Velocity NoteMagix M10 A82 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Sonuç
Sam Middleton
401 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G9
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 309
