Ana içeriğe geç
Velocity NoteMagix M10 A82 Keyboard Replacement
Neye ihtiyacın var
  1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Keyboard Replacement: adım 2, 2 resimden 1. Velocity NoteMagix M10 A82 Keyboard Replacement: adım 2, 2 resimden 2.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Keyboard Replacement: adım 4, 1 resimden 1.
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Keyboard Replacement: adım 5, 1 resimden 1.
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
Sonuç
Sam Middleton
401 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G9
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 527
