Ana içeriğe geç
Vent Panel Disassembly
Neye ihtiyacın var
  1. Vent Panel Disassembly, Remove Service Panel Screws: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    FixBot'a Sor
    Yorum Ekle
  2. Vent Panel Disassembly, Dislodge Service Panel: adım 2, 3 resimden 1. Vent Panel Disassembly, Dislodge Service Panel: adım 2, 3 resimden 2. Vent Panel Disassembly, Dislodge Service Panel: adım 2, 3 resimden 3.
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    FixBot'a Sor
    Yorum Ekle
  3. Vent Panel Disassembly, Remove screw covers: adım 3, 1 resimden 1.
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
    FixBot'a Sor
    Yorum Ekle
  4. Vent Panel Disassembly, Unfasten vent panel: adım 4, 2 resimden 1. Vent Panel Disassembly, Unfasten vent panel: adım 4, 2 resimden 2.
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
    FixBot'a Sor
    Yorum Ekle
  5. Vent Panel Disassembly, Remove vent panel: adım 5, 2 resimden 1. Vent Panel Disassembly, Remove vent panel: adım 5, 2 resimden 2.
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
iodyne
462 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 389
