Giriş
In this guide, you will learn how to remove and install the power cord of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord.
Neye ihtiyacın var
On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
Bir başkası bu kılavuzu tamamladı.
