Ana içeriğe geç
Verizon Ellipsis 10 Battery Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 10 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Open the SD/SIM card cover to start prying off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Verizon Ellipsis 10 Battery Replacement: adım 2, 1 resimden 1.
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
    FixBot'a Sor
    Yorum Ekle
  3. Verizon Ellipsis 10 Battery Replacement: adım 3, 1 resimden 1.
    • Follow along the edge of the device to undo all of the retaining clips.
    FixBot'a Sor
    Yorum Ekle
  4. Verizon Ellipsis 10 Battery Replacement: adım 4, 1 resimden 1.
    • Once all the clips are undone, the back panel should come off with little effort.
    FixBot'a Sor
    Yorum Ekle
  5. Verizon Ellipsis 10 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
    FixBot'a Sor
    Yorum Ekle
  6. Verizon Ellipsis 10 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the top piece of tape using an iFixit opening tool.
    FixBot'a Sor
    Yorum Ekle
  7. Verizon Ellipsis 10 Battery Replacement: adım 7, 1 resimden 1.
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
    FixBot'a Sor
    Yorum Ekle
  8. Verizon Ellipsis 10 Battery Replacement: adım 8, 1 resimden 1.
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
    FixBot'a Sor
    Yorum Ekle
  9. Verizon Ellipsis 10 Battery Replacement: adım 9, 1 resimden 1.
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Has anyone found a source for these batteries?
brianmjones - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 2,244
